Ga door naar hoofdinhoud
Model A1288 / 8, 16, or 32 GB capacity
20 Vragen Bekijk alle
Restore wont take hold
I have an ipod that I've restored three times now and when re-booted will go back to the restore screen again. I've restored using itunes in both normal mode and by putting it into DFU. I don't know the history of the ipod but it does have the moisture indicator red.
I've also used iReb to see if I can get it out of the restore loop and that didn't help either. Is this Ipod a lost cause? Should I keep restoring it? Should I try an earlier firmware than the latest? Any other suggestions?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Did you try the fix recovery option in redsn0w?
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Good idea, but didn't work.
With your idea I did try the latest redsnow but it doesn't support autodetect on the 2g so I couldn't use it. This led me to try tiny umbrella recovery and it didn't fix problem either.
door
Hmm... Maybe try a custom firmware? or a older redsn0w?
door
I found an older firmware which seemed to work. I put it on and ipod booted to main screen and I was able to put some songs and apps on it. Unfortunately, even though I was able to boot a few times immediately after that, when I booted the next day it went into recovery mode again.
door
make my ipod disabled unlock
Voeg je antwoord toe
Carpenter940 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 471
