How do I fix horizontal lines on screen?
The screen all of a sudden showed horizontal lines. I tried restarting it while connected to power and nothing changed.
Thank you for your help!
Is dit een goede vraag?
First, make sure you aren't accidentally booted into Safe Mode. When you are in Safe Mode some of the graphics will be reduced which could produce strange lines on the screen. If the issue is happening outside of Safe Mode, then you probably have a hardware issue. In most cases for these newer models, if you're seeing lines on the display it means that the display assembly is damaged. If you have AppleCare I would recommend contacting Apple to see if the repair is covered under your warranty. Otherwise you may need to consider replacing the display assembly. Good luck!
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 135
Lines can be a few things. Add a picture into your question so we can take a look at what sort of lines you mean! :)
door Alisha C
