Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Apple ID not active
Apple I’d not active what’s the solution to it
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Do you mean that the device is Activation Locked to an Apple ID? Or do you mean there's a problem with the Apple ID and it isn't fully functioning? If the device is Activation Locked, then you'll need to enter the credentials for the Apple ID to unlock it. If you don't know the Apple ID credentials you can attempt to reset them here. If there is a separate problem with the Apple ID, you may need to contact Apple to resolve the issue. You can contact them through the support options on their website. Good luck!
Was dit antwoord nuttig?
Score 1
It's blocked I can't unlock it
Voeg je antwoord toe
Kehinde Oluwafikunayomi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 161
