Ga door naar hoofdinhoud
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
465 Vragen Bekijk alle
Why is my pa3 not recognizing disks?
When putting in a disk it pulls it in normally but then keeps pulling it in the same way it would if you took the disk out after touching the sensor inside the reader. After it's done overly sucking it in the ps3 doesn't recognize the disk.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
  1. Dirty or faulty disc drive sensor: The sensor inside the disc drive that detects the presence of a disc may be dirty or malfunctioning. Try cleaning the sensor with compressed air or a soft, lint-free cloth. Be gentle and avoid applying excessive pressure.
  2. Disc loading mechanism issue: There might be a problem with the loading mechanism that pulls the disc into the drive. It could be misaligned or worn out. In this case, you may need to have the disc drive repaired or replaced by a professional technician.
  3. Firmware or software issue: Occasionally, firmware or software glitches can cause disc recognition problems. Ensure that your PS3 is running the latest system software version. You can try updating the firmware or performing a system restore to see if it resolves the issue.
  4. Disc format or condition: Make sure that the discs you are inserting are compatible with the PS3 and are in good condition. Scratched or damaged discs may not be recognized properly. Try using different discs or cleaning the discs if they are dirty.
Was dit antwoord nuttig?
Voeg je antwoord toe
Conner Heidecker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 19
