Ga door naar hoofdinhoud
Repair and disassembly guides for desktops manufactured by Acer.
70 Vragen Bekijk alle
My all in one Acer Aspire ZC-700G is in a boot loop.
My all in one Acer Aspire ZC-700G is in a boot loop. Whenever I power it on, it gets to the Acer logo and resets. This didn’t start until after the latest update.
Update (05/16/23)
When I press F2, the computer restarts before it can open the bios screen.
Is dit een goede vraag?
1 Opmerking
Which model of Acer All-In-One? It should be marked on the back of the case. Can you get to the BIOS screen by holding down the F2 or the Del key when you power on?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Something has likely got corrupted during the up date - Windows I presume?
Taping the F2 or DEl key sometimes works better than just pressing and holding down. If you still can't get into the BIOS shut down the computer by holding the power button down and unplug all cables. Take the back cover off (see video below) and disconnect the hard drive and take the RAM out. Power on again. This will some times force the BIOS screen to load.
How to open back panel video
While inside, taking out the BIOS/CMOS coin battery should reset the BIOS to default settings.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Tyson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 188
