Ga door naar hoofdinhoud
Wired controller for the Xbox 360 console.
My Controller flickers on then off right away and doesn't function
My xbox 360 afterglow controller has always had it's issues with powering on with me having to shift the cord at different angles, but now whenever I plug it turns on but a milisecond it shuts off, this happens everytime I plug it in, Any suggestions?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
@joelgunaratnam this "shift the cord at different angles" sounds like either a bad solder joint or a broken cable. By now it most likely is all disconnected. time to take it apart and trim the ends of the wire. Then resolder them properly. Take plenty of pictures so you do know how and where each wire connects. PDP Afterglow Wired Xbox 360 Controller Cable Replacement
Was dit antwoord nuttig?
Voeg je antwoord toe
joel gunaratnam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 210
