Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Sorvall ST 16 Centrifuge - Temperature sensor mechanism?
We have a centrifuge set at room temperature but after a 5 minute spin, samples are cold and frost can be seen within the chamber. Does anyone know how to diagnose and fix this situation?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
This problem was solved by emailing technical support at ThermoFisher. Here was the fix:
"First check that your temperature sensor hasn't fallen in to the motor chamber.  To do this remove you rotor and examine the rubber motor boot.  The sensor should be sticking out of that rubber seal.  If not it has fallen in the motor chamber.  You can remove the rubber motor boot and fish it back up and put it back in the seal."
Was dit antwoord nuttig?
If your Sorvall ST 16 centrifuge is producing frost despite being set to room temperature, the issue may be related to a faulty temperature sensor, cooling control system, or refrigeration relay. Check the temperature settings and allow the chamber to stabilize before operation. If frosting continues, inspect the sensor and cooling system through the model-specific service procedure. It is advisable to contact a qualified centrifuge technician for sensor testing and calibration before further use.
Voeg je antwoord toe
Small Mechanic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 596
