Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Deze 7-inch tablet met 1440x900 resolutie en Android Jellybean werd in september 2013 uitgebracht en verkocht door Tesco. Het apparaat werd in oktober 2015 uit productie genomen, nadat het was opgevolgd door de Hudl 2.
How to screen replace?
screen is smashed how do i get new screen connected
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi
I’m not sure if they make parts for this as they aren’t common and would probably cost more to repair than I would to buy new unfortunately
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 1
Best bet on this is to keep an eye out on eBay for a used screen like this one.
Tesco Hudl 1 Genuine LCD Screen
Outside of that, most tablet manufacturers do not design their own LCD display, so it might be possible to disassemble the display and locate a manufacturer and part number on the back of the LCD itself. Of course, the problem there is that if your digitizer is broken as well, that won't help; I was unable to find anyone selling new parts for either the LCD or the digitizer on that tablet.
As far as instructions on how to do the replacement, I'm afraid you may be on your own there. No shortage of information on the Hudl 2, so that might be a place to start to at least get an idea of what you'll have to do, but no guarantees as to how similar the two models are going to be.
If you do end up tackling it, you could always write your own guide here on iFixit so someone who's following in your footsteps would have something to go by.
Good luck; let us know how it goes!
Score 1
Voeg je antwoord toe
Charlie Watton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 33
Altijd: 468
