Ga door naar hoofdinhoud
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
Camera viewfinder is black, and freezes the system
Hello, i recently picked up a 3DS XL and when i open the camera the viewfinder on the top screen is black and after 1 minute (or swapping to inner camera) freezes the system, i could replace it but i want to make sure that it isn't a software issue before doing that. Any help is appreciated, thanks.
Is dit een goede vraag?
2 opmerkingen
Can I do this safely even if I have a Luma 3ds on it?
door
Yep, luma won't interfere
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The easiest way to rule out a software issue is safe mode. Boot the 3ds holding L + R + A + D-pad up (not the circle pad), and you should boot into a system update screen. Go through the prompts, and check the camera when you're done. If it still freezes, you can try a system format, which should fix anything safe mode can't. Past that, it's a hardware issue
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
How i holding L+R+A+D-pas up and I don't know how.
door
It’s still dosent work and the device crashing by changing it back to back side or taking a photo/video
door
The most likely issue is the camera connector came loose. If you’re comfortable opening the unit you can reseat the camera flex cable and try to reassemble and test again.
door
Voeg je antwoord toe
vex zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 81
Afgelopen 30 dagen: 346
Altijd: 6,768
