Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Muffled Mic on rear camera when taking vid.
Why is it that when I take a video on my rear camera, it sounds very muffled, as if an air was blowing directly on the mic.
I've changed the charging port because before even the front cam and the voice recorder sounds muffled whenever i take videos or record voice memo. It fixed the front cam and voice record. But not the rear camera.
What seems to be the problem? I badly need help.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The microphone for the rear camera is located on the Power Button cable, along with the camera flash. I would try replacing that and see if it helps.
Replace a damaged or torn cable connecting the power/lock button to the logic board in an iPhone 6 Plus and fix an unresponsive power button. This assembly includes the internal power button switch and the camera flash. Afbeelding
Product
iPhone 6 Plus Power Button Cable
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Mark Mariano zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 362
