Ga door naar hoofdinhoud
2.3L 4cyl or 3.0L V6, 6th Generation
Cranks but won't start
2000 Honda Accord 2.3 cranks but won't start. I have replaced all the common issues ignition switch, ignition coil, etc. It is getting fuel has compression but the spark seems very weak. Tested the voltage to the coil and it is 3.3 volts. Any suggestions on where to go next?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
The voltage from the coil seems low. Not much experience with Hondas though. Is that the output voltage or what's coming into it?
Was dit antwoord nuttig?
1 Opmerking:
That is voltage to the coil
door
if you haven't done this yet, check your eng, fuse. my car would crank but not start & that was it. it's a 10amp
just now by will
Voeg je antwoord toe
Michael Leonard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 399
