Ga door naar hoofdinhoud
1,7 GHz dual-core Intel-processor (Turbo Boost tot 2,6 GHz) met 3 MB gedeelde L3-cache
MacBook Air 2012 - WiFi not detected!
Hi!
I have a really nasty and dusty Macbook Air mid 2012, which couldn't turn on. After a dust-off and cleaning it turned on again. I think the charging port was making a bad connection. I have cleaned the logic board too with IPA and a light brush.
I have Bluetooth, but not WiFi. The WiFi card is getting a little bit warm, but nothing crazy.
How can I figure out what the problem is? Any known voltages out there or something like that? Can the U1800 (pch) chip have anything to do with this? Could the Airport card be half-bad?
Thank you in advance!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
The AirPort board has two connections. The Bluetooth uses USB, where WiFI uses a PCI connection.
So it’s possible one connection works and the other not. So it could be a bad coax cable or a bad board.
MacBook Air 11" mid-2012 AirPort/Bluetooth-kaart vervangen
Was dit antwoord nuttig?
2 opmerkingen:
Do you have an idea to find out if the Airport card is the problem or if it is something else.
I have a Macbook pro early 2015. Would it hurt if I tried to swap the WiFi cards?
door
@zoneknud - That’s what I would do, just swapping the AirPort board.
door
Voeg je antwoord toe
Anders zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 288
