Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Cardo Systems motorfiets bluetooth-headsets: Packtalk, Smartpack, Packtalk Bold en Packtalk Black
Replacement USB connector P/N on PCB?
As with many other users I have a Packtalk Bold out of warranty with a bad USB connector. It works if the cable is held pressed up or down. Many have had solder failures but not this one, I need a new connector but studying images and footprints at Mouser and DigiKey has failed to ID a likely candidate.
Is dit een goede vraag?
Score 2
6 opmerkingen
Did anybody ever find a solution to this problem
door Deel
The YouTube link shows someone doing it, not someone willing to share the P/N.
door Deel
Meh. My question is, “what is the part number of the usb socket?” The YouTube video and poster refuses to share his secret.
door Deel
1 commentaar meer tonen
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
you can find the correct USB connector here....warning...its a bit tricky without the right equipment. I have successfully fixed two so far with USB replacements. If the trace has pulled away from the board....you may need to fix that also. https://www.amazon.com/gp/product/B00NQB...
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you I bought a couple of these off Amazon from your link from uxcell and had my local “iKrack” micro solder shop replace one for me. It worked well.
door Deel
Het nuttigste antwoord
Afbeelding
is standard micro usb, but many Times on this model is the PCB lines missing, then need make jumper.
Score 2
There is a good Youtube video on this process: https://www.youtube.com/watch?v=FLr-Keiv...
Voeg je antwoord toe
David kelly zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 43
Altijd: 2,002
