Ga door naar hoofdinhoud
De Moto G4 Plus is een verbetering van Motorola's Moto G4. De Moto G4 Plus biedt een vingerafdruksensor, een grotere geheugencapaciteit en een verbeterde camera achteraan. Modelnummer XT1642 en XT1644.
My display remains greenish all the time
Recently I has dropped my phone into water then the camera module get moisture. That time I was very hyper then took it to a phone servicing centre and clean the moisture but the display got tint issue......and also ghost touch issur.....my display remains greenish all the time .. what can i do now??
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
@srtechente59078 At this point the most obvious solution for you is to replace your screen. Since both the LCD and the digitizer are contained in the display assembly, replacing it should solve all of the problems you're seeing.
The good news is your prompt action with getting the phone cleaned probably saved it, but displays are notoriously sensitive to liquid damage.
Replacing the screen is something you can do yourself, but if you're not comfortable then you'll want to take it to a service center to have the repair done. Here's the iFixit guide that will take you through the procedure step by step.
Motorola Moto G4 Plus LCD Screen and Digitizer Assembly Replacement - iFixit Repair Guide
You can buy a replacement screen right here on iFixit or go shopping yourself on places like Amazon, eBay and AliExpress.
Moto G4 Plus Screen: LCD Display + Digitizer Replacement Kit - iFixit
If you don't have the tools already, I'd recommend the Fix Kit version. For an extra $6 USD you will get all the tools needed to open up the phone, remove all the internals and replace them into a new display, along with all the adhesives needed to put the phone back together again.
Replace a front glass digitizer panel compatible with the Motorola Moto G4 Plus model XT1641 smartphone. 5.5 inch 1080 x 1920 pixel LCD Display. Includes the LCD display, front plastic and metal frame, edge bezel, battery adhesive, earpiece speaker, fingerprint sensor, and vibrator motor. Afbeelding
Product
Moto G4 Plus Screen - Genuine
$29.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
S&R Tech& Entertainment zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 227
