Ga door naar hoofdinhoud
Uses a smaller heatsink and a user-screwable stand.
Front USB and USB-C ports not working
I took apart my PS5 to deep clean it, wasn't the first time I've done this. But when I put everything back together, I tested the USB and USB-C ports, and they were not working. The backports were fully functional. Any help?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You may have connected something wrong, missed a connection, or messed up the port
Was dit antwoord nuttig?
Score 2
The flex ribbon connector that connects the usb A/C board to the main board is very fragile. Inspect the cables gold pins to see if they are damaged, also inspect the gold pins inside the connector as they can also get mangled.
Voeg je antwoord toe
Odiin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 28
Altijd: 1,392
