Ga door naar hoofdinhoud
My phone is telling me that it is overheating and I can not charge it
Is dit een goede vraag?
Score 4
5 opmerkingen
@adrianpohl3196 Can you install Device Info HW (https://play.google.com/store/apps/detai...), go to the thermals section, and upload a screenshot of the results)?
door
is the phone warm to the touch?
if you power it down and turn it back on, will it still give you that error code?
does wireless charging (if possible) still work?
door
No phone is cold and I tried to restart but it did not work. It is a Samsung m32 so it can not wireless charge
door
@adrianpohl3196 is your battery health in good shape? is there any signs of swelling batteries? (small opening on the sides of the phone, bumps on the back of the phone, back on the phone is swelling)
door
No the batterie is not swollen and I opened it up and the batterie was completely fine
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi I can answer your question 100%!,
I have a m32 with the same problem and all I just did is mess around with the Large SUB cable, I reconnected it a couple times on the motherboard side
Was dit antwoord nuttig?
Score 1
Hello,
There might be a issue with your battery, that might need to be replaced. When batteries age, they can start to overheat, and cause your phone to limit performance. I would recommend you shut your phone down and get it fixed ASAP. If you keep using your phone while this is occurring, it might cause more severe damage. I hope this helps!
2 opmerkingen:
The phone is 8 months old and the battrie life is completely fine but I can not charge it
door
Did u find solution?
I have the same problems now
door
Voeg je antwoord toe
Adrian Pohl zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 40
Altijd: 617
