Ga door naar hoofdinhoud
Released in 2020, this model retains the same overall design and build quality as the T480/T490, but with a revamped naming scheme in line with Lenovo's X-series Thinkpads and newer CPU/RAM configurations.
Keyboard liquid damage repair
I spilled some liquid on the key board. Now the key board is not working anymore. With an external keyboard everything works well. The touch board is still in order and works well. How can I fix the key board issue? Could you add a guide as to how to take apart the keyboard? Thanks in advance
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hey! Good that everything else works! It seems like you will need to replace the keyboard. I linked some resources below for the replacement and parts.
Use this article to replace the keyboard.
Use this link to use for the keyboard replacement.
Hope you find my info useful! ❤️
Was dit antwoord nuttig?
Voeg je antwoord toe
Natanja Slager zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 49
Altijd: 550
