Ga door naar hoofdinhoud
Location for Miele dishwasher repair and troubleshooting.
6 Vragen Bekijk alle
Miele G2183SCVi Dishwasher stops mid-cycle, beeps, all light flashing
My dishwasher runs for somewhere between 2 minutes and 17 minutes before it stops and beeps constantly. Opening up the door, all 6 lights are flashing and the pump in the bottom continues to run for several minutes. I have validated that water is being circulated in the machine and the pump is working (pumped into a bucket).
I can't seem to find how to determine error codes on this machine as there is no display. Any insights would be greatly appreciated.
Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Okay, I was able to get into the service/diagnostic mode of the dishwasher. When I do so, the Intake/Drain flashes once quickly and the SaniWash led has 0 short flashes and 7 long flashes. From the Technical Information G1000/G2000 Manual, it looks like this is an F70 error
Update (04/01/23)
I performed the following steps to get have the LEDs display the error code:
1. Open the door.
2. Switch off the dishwasher.
3. Press and hold the Program button.
4. Switch on the dishwasher.
5. Release the Program button.
6. Immediately press the Program button 3 times; on the 3rd time, hold until the “Rinse & Hold” LED flashes.
7. Release the Program button.
If the “Rinse & Hold” LED does not light up, repeat the procedure.
The “Rinse & Hold” LED should flashes slowly (1 flash per second) indicating successful enter
Press the Program button 1x.
If the “SaniWash” LED displays a fault, check if further faults were registered.
Press and hold the Program button until the “Intake/Drain” LED lights up.
Then briefly press the Program button.
Count the flashes of the SaniWash LED taking note of the flash flash and long flash.
Update (04/01/23)
Look at the table on page 147 of the following document:
https://applianceservicesecretsmembershi...
F70 is a pump leak in the bottom of the dishwasher. There are several YouTube videos which explain the next step. This was the most helpful for me: https://www.youtube.com/watch?v=D3sUuD4Q...
Another suggested pulling out the dishwasher, removing the bottom plate and running the dishwasher while on blocks so that you can see the source of the leak. Once the cause of the leak is determined, the appropriate next steps can be determined.
Update (04/01/23)
Issue Resolved per the procedure above
Was dit antwoord nuttig?
1 Opmerking:
My machine was leaking from the EGR valve (top yellow valve on the left side. The o-ring was dried and no longer sealing. I could not find a part number for the o-ring but it measures 10mm ID, 16mm OD, 3mm thick. They carry them on Granger. I will update once received and replaced.
https://www.grainger.com/product/GRAINGE...
door
Voeg je antwoord toe
Steve Sifferman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 256
Altijd: 3,151
