Ga door naar hoofdinhoud
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
268 Vragen Bekijk alle
Help me troubleshoot my iMac.
I replaced thermal paste, replaced the HDD with a SDD, and cleaned out the fans and case. No accidents, all connections accounted for. Now, absolute silence and no picture when power button is pushed. I've re-opened twice after going to google and to apple support and I can't find anything wrong.
Is dit een goede vraag?
1 Opmerking
I'm afraid this did not help. I have purchased a replacement power supply from eBay. I have some compatible SODIMMS which will replace the current ones. I 'm arranging for someone to help me check the power switch ( this is a stretch, I know). If this doesn't work, I'm done, and I will part it out and sell it. Thank you for your help.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You likely didn’t sit the CPU chip into the socket correctly. The design Apple went with is a bit tricky! Go back removing the heatsink and inspect the chip and the socket for damage if you are lucky, reseat the chip but soften the springs a bit.
Was dit antwoord nuttig?
1 Opmerking:
I'll let you know. I'm grateful.
door
Voeg je antwoord toe
todoroffc zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 31
