Ga door naar hoofdinhoud
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Is it possible to use 32GB of RAM?
I just got a CPU upgrade for my iMac (i7-3770s) and now I’m wanting to do a RAM upgrade whilst the logic board is out. Intel’s website says that the max memory is 32GB, but I don’t know if it is different on the iMac, because you know, apple… Also it is the 21.5” model so there’s 2 RAM slots and you have to take the logic board off to upgrade.
Thanks, Ryan
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Sorry, you’re stuck at 16GB.
While the CPU can address 32GB you only have two SO-DIMM slots. The 27” offers the four SO-DIMM slots and can support 32GB.
Was dit antwoord nuttig?
2 opmerkingen:
Wait, what if I use two 16GB modules?
door
@ottobunnycoder - This gets into which came first! I don’t think Apple enabled all of the address lines to support the denser SO-DIMMs. But if you’re game give it a try! But make sure you can return them if it fails.
door
I cannot find any documentation that will prevent you from using 2 16gb sticks for 32gb of ram.... However... apple.... so if you find cheap sticks I would give it a shot worst it will do is yell at you.
1 Opmerking:
Have you successfully upgrad RAM to 32GB? It work?
door
Voeg je antwoord toe
Ottobunny zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 187
