Ga door naar hoofdinhoud
Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
832 Vragen Bekijk alle
Is DD2 the same as DDR2?
I have a 1GB stick of memory labeled DD2. I got it from a friend who thought it would work with the A1055 iBook. However, it does not. So, I'll be selling it. But a quick eBay search for DD2 turns up around 8 results. So, I ask this: are DD2 and DDR2 one and the same?
Thanks!
Is dit een goede vraag?
Score 1
1 Opmerking
Was it from a reputable manufacturer? Some very low budget ram can be wrongly labelled by manufacturers who are not reputable, an do not actually know the correct terminology. I know its a stretch, but it might be true. As for A1055 iBooks you'll need DDR RAM.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Never heard of DD2 - The Proper term is DDR2 (Double Data Rate Version 2)
iBooks do not take DDR2 they take DDR (without the 2) Usually DDR 333 (PC2700)
Was dit antwoord nuttig?
Score 3
1 Opmerking:
That's what I thought. But it's really weird... the "DD2" stick kinda fit in an old iBook G4 board, but it wouldn't fit in a board from the same family. To Craigslist it is then!
door
you're all wrong i have 2 sticks right in front of me. they are for real.
they read 1 GB, DD2 DIMM,F made by PNY A0TFT
Score 1
1 Opmerking:
7 year old post.
door
Here is link to what I have.. Thought it was DDR2 based on the label.. It is not?
http://www.dreamhardware.com/memory/memo...
MEMORY PNY 1GB, DD2 DIMM,F A0TFT PO:134270.19 (REFURBISHED)
Pin set is different.. notch off slightly
1 Opmerking:
If the notch is off slightly it could be DDR3
door
Voeg je antwoord toe
Josh Calvetti zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 11,127
