Ga door naar hoofdinhoud
Apple AirPods zijn draadloze oortjes die in december 2016 zijn uitgebracht.
Can I clean AirPods using an ultrasonic cleaner?
Hi! I have had a pair of 1st Gen AirPods for a couple of years and as expected, they got clogged up with ear wax. Using a toothpick doesn't really do the trick as the wax is stuck in the mesh.
My question is: as I already have an ultrasonic cleaner, could I use it to clean them? Alternatively, can I use some cleaning alcohol on the mesh to try to get it out of there (PhoneFixCraft does this on YouTube).
I am afraid the liquid might damage it, but the alternative is buying a new pair, which would really be a waste as they work perfectly otherwise.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi
I really wouldn’t do this as ultrasonic cleaners are really good at putting holes in thin things
The speakers in your airpods have a thin plastic diaphragm that helps makes sound
When ultrasonic frequencies hit that chances are they will put holes in it,a way of demonstrating this is by putting a square piece of aluminium/tin foil in and watch what happens
What I would recommend is getting a small brick and a thing pick and cleaning them that way with isopropyl alcohol,that way is much much safer
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Andrei Covaci zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 113
Altijd: 4,526
