Ga door naar hoofdinhoud
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
Best way to remove top screen protective film?
Ive seen videos of people removing the top screens film with a hair dryer, but curious if using like an air station is better, or if theres a alternative better way to remove the scratched film I’m trying to replace. I have an air station but don’t want to damage the ds itself. Low heat? High heat and try to get it off quickly? Any help is appreciated
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You could try very carefully and slowly using a razor blade. Wedge the razor blade in between the film and the screen and only push enough to get a small corner to grab and peel slowly.
Steam will also work. Always do low heat.
Was dit antwoord nuttig?
Voeg je antwoord toe
Cody DaGoat zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 130
