Ga door naar hoofdinhoud
Televisions made by LG.
25 Vragen Bekijk alle
Dim grey screen, no picture, good sound.
Hello,
I have an LG 55 inch smart tv, 55UK5090PUA. The screen suddenly went from a solid picture to a dimly lit grey screen. There was no transition where it was intermittent - it just stopped displaying a picture, although when I pressed hot buttons to get to a streaming service, I could hear the sound.
After trying the reset/troubleshooting, I replaced the Main Board with the same replacement part (EBT65513202), plugged everything back in, with the same results. I guess now I have a back-up.
Does anyone have a suggestion on what I should check next (and how)? With the back off the TV, you can see the back lights on for sure, so I believe there is juice moving through the power board.
Thank You in advance,
Evan
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I don’t understand what I did, but I found this YouTube video of a guy that ended up blocking one of the paths on a flex cord that was shorting out between the screen and T-Con … and it worked for my issue too.
Here is the link, in case anyone else has the unanswered problem similar to mine. I’m sure there is a more permanent fix with new parts, but I’ve spent enough time and money on this TV already, so I’m going to call it good.
https://youtu.be/tCknTVbZ3I8
Was dit antwoord nuttig?
Voeg je antwoord toe
Evan Winney zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 177
Altijd: 1,564
