How do I change cigarette lighter in 2008 Nissan Sentra not the fuse
I’m trying to figure out how to change my cigarette lighter in a 2008 Nissan Sentra I changed the fuse and still not working can someone help me please…
Is dit een goede vraag?
Examine your cigarette lighter. The hot end that glows is a one piece coiled heating element. It should not show damage, a physical break in the coil. 12v current is drawn with several amps thru this coil to create heat until it glows red hot, then ejected to inform you that the lighter is ready. If the element is broken, replace it. If it's not broken, measure the voltage between the center pin and side of the socket to ensure 12v is available. Some vehicles shut off power, requiring the ignition switch turned on. Other vehicles leave the lighter hot at all times.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 205
