Ga door naar hoofdinhoud
How to pry power supply connector from logic board
I'm trying to install a new power supply I just received from you. I've tried everything according to your instructional video but I cannot pry the connector away from the logic board. I've gone so far as to remove the power supply with the connector attached so I could get under the connector but it's no go. Can you help?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hey Jsoter,
The connector is stuck in there pretty darn tight. We've found that the best method for disconnecting it has been to depress the connector lock while using a heavy duty spudger, or other gentle but strong prying tool, to firmly jostle either side of the connector until it comes free. It usually takes a few tries at each side, but as long as you are depressing the connector lock at the same time, it should come free with some persistence.
Hope this helps! Let us know how it goes.
Heavy-Duty Spudger Afbeelding
Product
Heavy-Duty Spudger
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks. I finally got it.
door
Right on; glad it worked!
door
Voeg je antwoord toe
jsoter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,010
