Ga door naar hoofdinhoud
Repair and support for the 2015 version of the Google-produced laptop line, the Chromebook Pixel. This newer version improves the processing power, battery life and add new features to the 2013 model.
14 Vragen Bekijk alle
Remove R/W screw to boot into Windows
I am looking to do a complete OS installation of Windows. I know the process of completing that through Mr. Chromebox installation guide. However, he mentions that you need to open the Chromebook and remove the R/W screw inside in order to fully flash an alternative OS such as Linux or Windows. Has anyone attempted this? If so, please describe where the screw is located? I know to open the Chromebook you just pry up the rubber pieces on the bottom. However I want to make sure I am only removing the correct screw on the inside.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I found a video on youtube showing EXACTLY what screw to remove. Wanted to share with the community. https://youtu.be/wOsezY7znZ8
If you need any help please feel free to reach out to me. I'll be giving this a try as well as performing the installation of Windows. Already have Dual Boot of Ubuntu/Chrome OS - due to no longer receiving updates I use Ubuntu ONLY at this point other than to run some terminal codes to install other flavors of Linus from ChromeOS.
Was dit antwoord nuttig?
Voeg je antwoord toe
Rickluebke zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 80
