Ga door naar hoofdinhoud
Cursor stuck in the upper left corner
I just replaced the logic board and optical drive and when I boot up the mouse pad does not work. What should I check 1st?
Update
The built in track pad is not working. I am checking the connection now. I was hoping to find out which connection is the likely problem.
thanks for the help
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Do you mean you're running a USB mouse or the in-built trackpad on the keyboard area? If it's USB the check ports externally for dirt/bent pins and for solder crack internally. If it's the trackpad and you had no previous prioblems then you should recheck your connection there.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Reseat the keyboard connector making sure you haven't bent over any pins on the connector: PowerBook G4 Aluminum 12" 1-1.5 GHz Keyboard Replacement
door
The 4 pins are straight and connector seems fine. Yet no track pad working yet.
USB mouse does work.
Voeg je antwoord toe
John SS zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 736
