Ga door naar hoofdinhoud
De SteelSeries Stratus Duo is een draadloze controller voor meerdere platforms om te gamen op Windows, Android, Oculus Go en Samsung Gear VR. Hij werd uitgebracht in februari 2019.
Does this controller vibrate during game play?
Hi I bought a steel series stratus duo controller and realized the controller doesn't vibrate. Is mine a defect or is this not a feature on this particular controller?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
The SteelSeries Stratus Duo is designed to provide haptic feedback (vibration) during gameplay on compatible devices. If your controller isn't vibrating, it could be due to a hardware or software issue. Maybe try some of this
  1. Check the software: Make sure you have the latest firmware installed on your controller and that the device you're using it with is compatible.
  2. Check the settings: Check the settings on the device you're using the controller with to ensure that vibration is enabled.
  3. Try a different device: If the controller isn't vibrating on one device, try using it with another device to see if the issue is specific to that device.
Good Luck!
Was dit antwoord nuttig?
stratus duo has 0 vibration . ive taken this apart. there are 2 weights in the handles. no trigger motors.. and doesnt look like the pcb even has a place for vibration.
Voeg je antwoord toe
Christopher Hernandez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 1,036
