Screen shuts off after replacement
Hi.
I have a weird problem that hopefully somebody can help me with. I changed the screen on a MacBook Air 2019 and after the screen replacement it now boots directly to a black screen (boot sequence is working/apple logo + progressbar is showing). If I shut the lid and opens it again, the image appears for 5 seconds before it turns black again. There's a tiny blue dot in the uppermost left corner when the image disappear. Backlight remains on and adjusting it works; but the image is gone.
External monitors work fine. Recovery/safe mode works fine. I've reseated connectors, but everything looks fine. Cleared NVRAM/SMC, reinstalled macOS.
Video:
The previous monitor showed an image constantly but had purple lines and incorrect coloring.
Thanks for your help.
Is dit een goede vraag?
How did the installation process go? Do you feel like the display may be a used part, or may have been damaged during the installation? You could try disconnecting and reconnecting the display. Does the laptop display have the same problems when the accessories are disconnected?
door Zach
@zpl Thanks for the reply. Installation went smooth, no damage at all. Hard to tell if it's a used part, it was bought as "new oem" which it definitely ain't. Weird thing is that everything works until the display drivers load in MacOS - recovery installation + boot shows image just fine. No accessories attached. I'm thinking it's a bad display, however i just want to make sure it's not something internal in the MacBook.
door simonsessingoe
