Ga door naar hoofdinhoud
Glow is designed with sleep in mind. Its self-dimming, warm light lulls you into better, deeper sleep.
4 Vragen Bekijk alle
But now one of the two pogpins is broken
I live in Switzerland and have always charged my glow with a US-EU adapter. But now one of the two pogpins is broken and i need an other way to charge it. At the Moment i use a Labor Power Supply and charge it directly.
Output: 9V / 2A
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@pogopooc, Is it not feasible for you to replace the broken pin? On the previous question on this glow light we talked about sourcing the pins and referred to a video showing the process of replacing them on a different device.
Wireless Charging base failures or options? - Casper Glow Light - iFixit
I'm not sure, but I believe Digi-Key ships internationally; otherwise I'm sure you can find it elsewhere on sites like AliExpress; here's just the first example that came up.
https://www.aliexpress.us/item/325680249...
Please post a picture of your broken pin and the charging base and we'll see what we can do to help you get it working again.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks @Jerry i ordered the pogopins at Aliexpress and i will try to replace them. But for now the Light is charged again and also there was a Firmwareupgrade. Looking forward for the Pins. Thanks
door
Voeg je antwoord toe
Pogopooc zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 22
Altijd: 654
