Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Vragen Bekijk alle
Which of the two Wi-Fi cards do I need , the 4.0 or the other
Hi 2012 MacBook Pro, wifi card which one as there’s two listed , can the 4.0 be fitted
Update (01/22/2023)
MacBook Pro Unibody (Early 2011-Mid 2012) AirPort/Bluetooth Board
MacBook Pro Unibody (Early 2011-Mid 2012) AirPort/Bluetooth Board Afbeelding
Product
$42.99
Is dit een goede vraag?
1 Opmerking
Can you link which two cards you mean? And confirm exactly which model you need the card for?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I see, there are two options in the drop down. If you are looking for the options specifically for the 2012 Unibody 15", Apple's technical specs list 4.0 as the standard Airport card. The same form factor is used for the 2011 and 2012 models, You can compare the number on the board to the one in your system now if you want to compare.
The 2011 model made use of the Bluetooth 2.1 card.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
That’s helped me out a lot , i have compared the old board and it’s the same as the 4.0 , thank you .I just wanted to make sure I didn’t buy the wrong one .
door
Voeg je antwoord toe
SIMON PIDGEON zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 42
