Ga door naar hoofdinhoud
Repair guides and support for smartphones manufactured by Doogee.
Trying to get the screen out to replace charging port
My Doogee S59 Pro's charging port was broken by a cheap type C charger, and it has glue all around the screen, which I need to remove to access the Charging board. Does anyone know of something that will dissolve the glue?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Heat! Just apply heat (100C) around the screen for 8 to 10 minutes, then pry on it (gently). I've been trying to get it out for months then saw this video! https://youtu.be/LM5Qae_A5oU
Was dit antwoord nuttig?
Score 1
1 Opmerking:
hi there, i have the same problem, did you finally replace the charging port ?
door
Voeg je antwoord toe
Anchevauls Walker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 406
