Ga door naar hoofdinhoud
Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
45 Vragen Bekijk alle
Cannot press home button on iPad 7th Generation
I recently replaced a customer’s home button and digitizer on his iPad 7th Generation, but the home button does not work and I have the button and the bracket glued down but it just pushes it to the bottom of the bracket. It is still glued and it is also connected and the screen is on but I cannot go home because I cannot press it. I checked the guide regarding replacing the home button, but still can’t solve this issue. Can someone please help me? Thank you!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Either rubber gasket is not adhered properly, or the clicker is missing - look for a small black dot in the middle of home button.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you I will try that and report back if it worked.
door
Voeg je antwoord toe
AvGeek Repairs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 67
