Ga door naar hoofdinhoud
1.6, 1.8, or 2 GHz G5 processor
131 Vragen Bekijk alle
It died, I ran a hardware test
iMac G5 Power PC 1989
The Hardware test hung up on the memory test for over half an hour( i finally gave up and quit the test). It doesn't
boot from a disk any more, I get a O with a/ through it.
Any ideas?
Update
I tried reseating the ram again and I got it to start up from the install disc. Right now it is Checking the installation disc so it can install the software. I'll let You know how that goes.
Is dit een goede vraag?
Score -1
1 Opmerking
I have two ram sticks. It booted from all three discs. The techtool disc ,the system disc and the hardware disc. The last time I tried it wouldn't boot from any of them. It gave me the O with the/ through it.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Try reseating your RAM one stick at at time in each of the slots. Here's how: iMac G5 17" Model A1058 RAM Replacement
Check the capacitors on the logic board for swelling and/or corrosion. Note the diagnostic light in the center of the logic board and tell us your results.
Was dit antwoord nuttig?
Score 7
14 opmerkingen:
OK, I reseated the ram. I have to order tools to get to the logic board. I'll get back to you when i get it done.
door
What I can see of the logic board looks fine. I plugged it in, the only light on it had an arrow pointing to it and it was green.
door
Do you have one or two RAM sticks? If only one, did you try it in both slots? Will it completely boot from the system installation disk (not the AHT)?
door
It wouldn't install the original software.It got so far and I got an error message.
I tried disk repair from the startup disc. It finished and said:
Checking extended Atributes file-invalid leaf record count-(it should be 600 instead of 150) I tried to boot it agin and i got a white screen with some typing in the upper left hand corner that said 'invalid memory------Type mac-boot. I typed mac-boot and the screen turned pink. I shut it down with the button onthe back and it spit the install disc out and shut down. Any ideas?
door
Please tell us about the RAM you are using
door
9 commentaren meer tonen
Voeg je antwoord toe
Karen Stoll zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 10
Altijd: 800
