Ga door naar hoofdinhoud
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
Dell XPS 13 laptop will not power on
When I press the power button the indicator momentarily comes on then goes off. I performed the power and rtc reset several times with no success. My next move will be to remove the back cover and pull the integrated battery connection.
If this doesn't work what will be the next steps to isolate the problem? I am debating whether to risk purchasing a replacement motherboard or play it safe and buy a new laptop?
Thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
So yes unplug charger and disconnect the battery connector,
Plug in just the charger and see if it powers up.
  • If yes then time to replace battery (how old is it?).
  • If no then remove the RAM memory, HDD/SSD hard drive and any cards like WIFI.
If it powers up now then the motherboard is probably good. Add one component at a time until it doesn't power up. That is the defective component.
Tell us how it goes.
Was dit antwoord nuttig?
Voeg je antwoord toe
Ray Dragowski zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 936
