Problems after SSD upgrade
Hello and thanks in advance for any help you can give me. I have an iMac late 2013. A year ago I replaced the HDD with an 2tb SSD and split the fusion drive, maintaining the 128 gb blade as the boot drive and the SSD for most of the applications and everything else. It has been working flawlessly so far.
Suddenly, the iMac has begun to act weirdly, booting but not recognizing the 2tb ssd, other times the ssd shows but suddenly disappears. I can boot in safe mode but it cannot access the documents in the SSD. It auto signed out from iCloud and I cannot sign in again. I re installed MacOS Mojave from recovery mode to no avail.
In case that I switch the SSD, which I think is going to be the final solution, could you please guide me with the necessary steps, considering that I have the OS and apple applications in the ssd blade and all other files in the 2tb ssd? Two more things to consider. I have a backup in Time Capsule (not sure how it deals with the split Fusion Drive) and I have an idle 2tb ssd blade.
Any comment is much appreciated
Is dit een goede vraag?
