Ga door naar hoofdinhoud
Professionele tool die waarschijnlijk wordt gebruikt voor het onderhoud van Nokia-telefoons. Apparaat is ontworpen als dongle met interne kaartlezer.
2 Vragen Bekijk alle
I didn't know the e-composite reference
can you help me? This electronic component, as in the picture, was removed from the xtw100 device, and I did not find it. I want to know its full name, quartz, and its reference, in order to replace it or change it with an alternative. Please help me and thanks.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Here's a link that shows the schematic for the programmer.
The crystal oscillator schematic component ref ID is Y2 and it has a frequency of 8MHz as can also be seen on the component in the image you posted. There is no other information as to its other specifications i.e. load capacitance, drive level, ESR etc so it will be difficult to know what the exact replacement would be. (examples only).
It may save a lot of time and hassles if you just purchased a new programmer. (supplier example only) as they are not that expensive.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Ahmed Paradoox zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 90
