Ga door naar hoofdinhoud
LG 27 inch UltraFine 5K IPS-monitor met macOS-compatibiliteit
I can't open monitor back cover
Could you help with instruction how to open monitor back cover - I can't understand how to do it? I already have been removed 4 screws, but how to find clips and what to do next I can't understand.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
the back usually doesn't come off on monitors.
the typical teardown is done by removing the screws (which you've done) and then carefully prying the bezel cover away from the display from the front of the monitor.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I have a feeling that I need to do something with clips, etc. Because I can't remove easily cover :(
door
hm. when I took my monitor apart I had to use some force to get the clips off because they are held on fairly tight
door
Voeg je antwoord toe
Ihor Syrota zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 31
Altijd: 1,292
