Ga door naar hoofdinhoud
The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
164 Vragen Bekijk alle
My X button wont work any more after using too much contact cleaner
This happened a couple weeks back when I noticed my joystick had drift, naturally I grabbed my WD-40 Contact cleaner, took the battery out and sprayed a lot on there, then I used my air duster to dry it called it a day, put the battery back in and loaded up blade and sorcery but I noticed my x button didn't work however the capacitive touch center still worked for it. I replaced the battery and let it dry for a bit but still it wont work.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
WD-40 is just mineral oil. The oil probably is lubricating the membrane and switch so much that it cannot read a press. To fix this I would recommend using 90% or higher isopropyl alcohol to clean away the oils. Be sure to not use WD-40 on electronics, as it is meant to lubricate and protect metal parts.
Was dit antwoord nuttig?
1 Opmerking:
The original poster said they used WD-40 Contact Cleaner, which is specifically used for electrical components.
door
Voeg je antwoord toe
oisin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 657
