Ga door naar hoofdinhoud
Repair and disassembly guides for electronic keyboards.
206 Vragen Bekijk alle
Yamaha DGX300 make loud hum when turned on and does not work.
Most of the time when I turn it on, I get a quick blast of static and then a continuous loud hum. Occasionally if I keep trying I don' get that and it works OK except for very low volume. I originally thought 60 cycle hum from some interference but tried on other circuits away from other devices with no change, except still once in a while turned on with no problem. I like the size and key style of this keyboard and don't want to scrap it. Advice and access to service manual much appreciated.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Hi
Here’s a link to the owners manual
https://www.manualslib.com/manual/196714...
Unfortunately I can’t find a service manual from somewhere that is trusted but if you look up Yamaha DGX-300 service manual you may be able to find one ,I can’t recommend the ones I found though
Here’s a disassembly video guide
https://m.youtube.com/watch?v=3ghMujk225...
You can follow the steps in the guide by in your case I would pay attention to where the speakers plug in and look out for any bulging or leaking capacitors (capacitors look like tall cylinders on the board)
If you are unsure of anything please don’t hesitate to let me know:-)
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
2 opmerkingen:
Thanks. I wish the video showed more of the electronics, but it's a good start.
door
@Charles Hadlock
That would be nice if it shows a bit more
From my experience keyboards tend to be pretty easy to look at as there’s isn’t too much to them
As long as you take photos of where the wiring goes and what boards and keys go where you should be all good for the disassembly side of things
door
Voeg je antwoord toe
Charles Hadlock zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 47
