Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de zevende generatie Apple iPad met Wi-Fi, verkrijgbaar met 32 of 128 GB opslagruimte. Uitgebracht in september 2019. Te identificeren aan modelnummer A2197.
Screen ghosting/Shadow on Led.
I cleaned the lightning port with electrical contact cleaner, worked great.
now the LED screen appears to have some ghosting/shadows behind the image. never had this issue before.
Is this fixable? or do i need to replace the LED.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi Oliver,
Depending on how heavily you doused the port with the contact cleaner, it's possible some of it made its way inside and got onto the LED/backlight/polarizer assembly. We've seen cases where a similar thing happened with isopropyl alcohol, and luckily after a couple of days the alcohol finally evaporated and left the screen okay.
In your case I'd suggest giving it some time to allow for the cleaner to dissipate; it may fix itself all on its own. If it still looks like that in a week then it might be worth considering a screen replacement.
Let us know what happens; if it doesn't clear up on its own, add some pictures to your question of what you're seeing and we'll see what we can do for you then.
Was dit antwoord nuttig?
Score 1
The first thing you should do if you're dealing with the ghost touch issue is to force restart your device. This will refresh the memory and reload all services. Needless to say, it brings your iPad back to its normal operation.
Regards,
Will
Score -1
1 Opmerking:
@willjoe it’s not a touch issue it’s an image issue.
door Deel
Voeg je antwoord toe
Oliver Byrne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 568
