Ga door naar hoofdinhoud
A portable and water resistant outdoor speaker designed by Bose for uniform coverage from any angle. Bluetooth, voice commands and auxiliary connections allow multiple connections options for up to 12 hours of use. A lightweight version of the Bose Soundlink Revolve+.
Flat ribbon cable is broken
Is there a possibility to get the ribbon cable between lower circuit board and top circuit board as a spare part?
Is dit een goede vraag?
Score 1
1 Opmerking
Did you find one as I'm after one too
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I found this. Search for "30-Pin FFC/FPC Flexible Flat Ribbon Cable Pitch 0.5-1mm 6/10/15/20/25/30/40cm" on eBay.
I ordered the 0.5mm pitch, 25cm long. I get 5 for $1.40. I haven't got it yet. Let me guess, you dropped yours and split the cable?
Was dit antwoord nuttig?
3 opmerkingen:
I noticed your original post was for the Revolve (Non-Plus) . Mine was for the Revolve Plus. You can probably find what you need on eBay.
door
Unfortunately, I have not found one yet. Apparently there are not as a spare part.
door
Hans, did you read the part number off the cable. This place on eBay will make custom ribbon cables. Just figure out how many pins it is and what length you need. It is probably 0.5 pitch.
door
Voeg je antwoord toe
Hans zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 37
Altijd: 756
