Ga door naar hoofdinhoud
Stopped dead while using; Power cord light goes out when connected
I used my Dell G5 15 5500 (purchased in November 2020) mostly for Minecraft and email... a little bit of surfing. It was pretty much plugged in all the time. I was surfing and it stopped working without warning. Tried turning on again but no signs of life... no screen, no keyboard lights, nothing, not even life enough to try POST. I tried unplugging power cord, waited, plugged it in and it looked like there was a spark when the cord was plugged in - also the blue light on the power cord goes out as soon as it is plugged into laptop. I thought it was a bad power cord/brick so ordered a new one. New cord had same result except no spark.... and new power cord blue light also goes out when connected to laptop. Laptop still dead. Holding power button down for at least 15 seconds shows no signs of life. I think this happened within a day of some sort of update, maybe windows update but not sure what type. Does this make any sense?! This has been a great computer for me and still had lots of useful life left, heh, until there wasn't any life at all! Has this happened to anyone else? Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Power mosfet has gone bad or a cap has blown on the board. The chargers have a fail safe built in. If you plug a charger into a laptop with a board issue the charger will go into safe mode which means it turns itself off. To reset it you need to unplug it and plug it back in. I’d find a local computer shop to take a look unless your confident in testing electronics.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you @strongbow
door
Voeg je antwoord toe
Pat (he/him) Harmon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 337
