Ga door naar hoofdinhoud
Flipper Zero is a versatile multi-tool device designed for hacking, debugging, and experimenting with various electronic gadgets and systems.
6 Vragen Bekijk alle
GPIO 17 for iButton Came off
Help, how do I repair GPIO 17 pins at the back which is used for the iButton feature? Tried opening the device and the clips were bit to tight when prying open and when I lifted the cover off it took two pins of the GPIO 17 off. Any suggestions on how to fix? Doesn't look like a solder tho..
Is dit een goede vraag?
Score 2
1 Opmerking
Have you resolved your issue? im having the same problem help please
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Unfortunately, the Flipper team does not currently sell replacement parts. However, you can contact them to be added to their waitlist.
Another option is to purchase a broken Flipper Zero that still has a functioning GPIO module and use it in your device.
You can also bypass the iButton pin by just connect a wire from GPIO pin 17.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Raymond zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 62
Altijd: 699
