Ga door naar hoofdinhoud
Repair and service information for the LG TrueSteam clothes dryer. Model numbers DLEX3570V, WM3670HRA, and DLEX3570W for graphite, red, and white colors respectively.
5 Vragen Bekijk alle
My dryer makes a buzzing noise when it starts.
The dryer makes a buzzing noise when it starts but works. However, after using it to dry two loads of laundry, when I press start for the third load, it buzzes and won’t start. If I wait about 30-45 minutes it will start again and works BUT after another two loads, it buzzes and won’t start. I always empty the lint trap after ever load and have taken the entire lint trap out and cleared out a lot of lint deep inside but that didn’t help. Any idea? The dryer is only 6 years old.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The motor has a mechanical, centrifugal switch, that engages a “start winding” until the motor overcomes the initial torque and starts spinning. I think in your case, the switch is going bad or needs lubrication. It “buzzes” because it is not fully engaging and the motor won’t spin up. If you were to literally “kick” the base of the dryer (don’t dent it!), you might actually cause enough vibration to ‘reset’ the mechanical switch inside the motor. If that works, it’s the switch. (Have some fun!)
Here’s an excellent video on a total motor replacement, that gets you to the motor to either try a repair or replace it. At this point, I do not recommend a motor replacement, as the symptom tells me the motor is working, just not starting correctly.
https://www.repairclinic.com/PartDetail/... (see the video on this page)
As he pulls the motor out, pause the video. The centrifugal switch is seen, down inside the motor frame, around the shaft.
Below is a second video, explaining the motor itself and possible troubleshooting and repair. Please do not attempt any repairs with the dryer plugged in, the 220V circuits can be deadly. If you open your dryer up (the first video has excellent steps), you might be able to lubricate the centrifugal mechanism to ‘unstick’ it and provide free movement.
https://youtu.be/fhZsqzU1hzQ?feature=sha...
This is a generic explanation, not the LG dryer, but it shows how the mechanism works. Spray it with a light lubricant (WD40 or LPS) and move it back and worth with a screwdriver (unplugged from the wall!!). You can reassemble the dryer without the drum and belt, to be able to plug it back in and start the motor, to watch the engagement (you must force the belt switch to the ‘ON’ position with tape or string. Be very careful, after you replug to the wall. You should hear the switch “click” as the motor starts, using the front panel to start and stop, multiple times to ensure it engages freely. Put the drum and belt back, removing your belt switch “jammer”, and try it out.
Good luck and I hope you save money fixing it yourself. Wear your badge of self repair proudly!
Was dit antwoord nuttig?
Voeg je antwoord toe
Donna Condon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 118
Altijd: 785
