Ga door naar hoofdinhoud
Model A1051 / 4 of 6 GB harde schijf
87 Vragen Bekijk alle
se me quebro el encendido de mi iPod,
I broke on my iPod, then I can not turn on,.
how can I fix that part?. I could go and watch this because I conorm all the pieces just are not built like this .. please if not too much trouble .. thank you very much
Is dit een goede vraag?
Score -1
2 opmerkingen
I don't think he has a iPod mini
door
Si es más facil para ud., puede escribir su pregunta en nuevo en español, con más detalles.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
OK: If I understand right you broke your iPod Mini and want to fix it. First, what part did you break?
Go to : http://www.ifixit.com/iPod-Parts/iPod-Mi... and find the part you broke. Order it and then go to: iPod Mini Repair and select the guide on how to replace the part.
If you can not find the part you broke at the site above you can try the following:
http://www.digiexpress.us/iPod-Mini_c_3....
But you should be able to use one of the guides listed above to install it.
If you want someone to just repair it, try: http://store.ifixiPodsfast.com/iPod-scre...
Be sure to get estimate first. Good luck
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
juan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 622
