Ga door naar hoofdinhoud
Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
Problem with battery board data cable.
I made it most of the way through a battery replacement. Unfortunately, my battery board data connector is messed up.
Note that there is no locking flap.
Compare this with the other end
And look! I can open it! ;)
And looking at the battery board from my old battery:
You can see that the flap is there.
I don't know how to proceed from here.
I think that the connector was defective before it went in. The scratches are me scrabbling around looking for the flap. It's simply not there.
Help? Can I swap this board for the old one or will that trigger some draconian drm?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
These battery boards can likely be swapped. But I would not recommend it and it will require soldering or spot welding to transfer it over since there are no easy connectors to sever or remake the connection to the battery.
It looks like you purchased this battery from iFixit if I am interpereting the pictures correctly (iFixit logo visible in pic 2). If so, I would get in touch with customer support and they'll get you squared away.
Was dit antwoord nuttig?
Score 1
Was this a used battery? If new return it as you got a used (abused) battery to get a replacement.
Voeg je antwoord toe
Seth Redmore zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 219
