Ga door naar hoofdinhoud
A laptop with great performance and mobility manufactured in 2011 by Dell.
My GPU won't give display (AMD Firepro m6100)
Hey, I was playing a game when suddenly my laptop display went off, and when I restarted the laptop, it stopped giving me display, When I turn on my laptop without a GPU, it gives me display So there is a problem with my GPU which I can't figure out. The graphics card is an AMD FirePro m6100. ******Although when GPU is connected the screen turns on but it is all blank. Kindly Help
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
Sounds like the AMD GPU has failed and when the GPU is removed from the motherboard it is working using the iGPU in the CPU.
Not much you can do if the discrete GPU has failed, except replace it
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Hey, Thank you for replying 😊
Yes it seemed this way that the GPUnhas failed is there's anyway i can know what make the GPU failed is GPU can be fixed?
And is there's any issue that can cause the GPU failed from my mobo just making sure.
Thanks
door
@Ali
Heat is one factor so maybe check if the GPU fan is OK (not clogged with dust) and also if the thermal paste on the GPU itself is OK and not dried out.
If it has dried out then the heat transfer from the GPU to the heat sink is not as effective and the GPU may get too hot especially if intensive video i.e. gaming, is being done
If the GPU has failed it can't be fixed it has to be replaced.
door
Voeg je antwoord toe
Ali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 159
