Ga door naar hoofdinhoud
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Vragen Bekijk alle
Ruined my ds lite please read πŸ™
Hello, today I decided to try to fix my broken screen by unplugging it and repligging the cable in and then when I tryed to put it back together I got the black cable STUCK under the already broken game card slot (missing pin) and now I had to remove the l trigger to even get it back together and when I try to turn it on it flashes the bottom screen and does nothing there’s no possible for my stupid brain to repair it myself also it has a broken hinge, L trigger, screen, and shell
CAN YOU PLEASE FIND A REPAIR SERVICE!,.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You might try bring it to someone who does cell phone repair, along with the link to this guide. A cell tech with soldering skills should be able to follow the guide and replace the parts that are broken. Sorry your attempt went so poorly. I cant give a name of someone to fix it because I don't know your location. Unfortunately the cost may be steep.
That horrible black cable needs to be pulled through under the cartridge port. A piece of floss or small ribbon or very fine solder can be snaked under the port to allow the black wire to be pulled through. It's really a pain and there are tons of comments in the guides about this.
Here are links to other guides that may be helpful:
Button replacement
Trigger Button replacement
Here's the DS Lite repair page
Again, sorry for the hard landing on this one.
Nintendo DS Lite Trigger Buttons Afbeelding
Handleiding
Nintendo DS Lite Trigger Buttons Replacement
Moeilijkheid:
Eenvoudig
20 minutes
Nintendo DS Lite Buttons Afbeelding
Handleiding
Nintendo DS Lite Buttons Replacement
Moeilijkheid:
Gemiddeld
1 hour
Nintendo DS Lite Afbeelding
Handleiding
Nintendo DS Lite Disassembly
Moeilijkheid:
Moeilijk
45 minutes
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Consider a profile picture but thanks for the nice response
door
Voeg je antwoord toe
Sqwerks zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 197
